Ir para o conteúdo principal
The Western Digital My Passport Ultra is a USB 3.0 portable storage device with capacities from 500 GB up to 5 TB.
37 Perguntas Visualizar todos
WD My Passport Ultra Not Detected
I have almost 1.5TB in this drive. Can still my WD My Passport Ultra be fixed? Or I just need the files within my hard drive.
- My WD My Passport Ultra was not showing in [My Computer].
- My WD My Passport Ultra cannot be initialized due to hardware error.
- My WD My Passport Ultra still not showing in [My Computer] using other USB Cord.
- My WD My Passport Ultra was shown in [My Computer] depending on how it was inserted to a USB Port but i could not open any folder/file within the drive.
Esta é uma boa pergunta?
Pontuação 2
2 comentários
i have problem with it
por
I need a program that can restore the wd passport
por
Adicionar um comentário
1 resposta
Pergunta mais útil
The drive being visible has multiple parts:
1) The USB interface must be working in order for the computer to recognize that there is a device at all.
2) The "driver" board on the disk must be somewhat working in order for the system to realize that the device is a disk and exists.
3) The actual spinning rust (called a disk) must be readable in order to store or retrieve files.
I think you may be having a problem with the USB interface and/or the "driver" board of the disc itself. Without seeing the device and poking around a bit, I can't be sure.
Dan
Esta resposta foi útil?
Pontuação 1
1 comentário:
Does it mean that i need to bring this on iFixIt so they could check it out?
por
Adicionar a sua resposta
Serniel Barbosa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 1,744
