Ir para o conteúdo principal
Versão renovada do iPhone 3G com velocidades de processamento mais rápidas. O reparo deste dispositivo é semelhante ao do 3G e requer simples chaves de fenda e ferramentas de abertura. Modelo A1303 / 8 GB,16 GB ou 32 GB de capacidade / Parte traseira em plástico preto ou branco.
1500 Perguntas Visualizar todos
Pergunta encerrada
After Battery Replacement - 3G radio signal Weak
I just replaced a friends battery on her iPhone 3GS.
Everything seemed great - back to normal - until she went home and now she gets 3G "No Service" - where before she had 1-2 bars.
Sure enough when she brought it back to the office the next day - there is only 1 bar - where my 3GS has a full 5 bars - we both have same exact model. Both are running iOS 4.3.1
Followed the iFixit guide very carefully - especially on re-assembley - but seems obvious that somehow I "broke" something regarding the cellular antenna - Wifi seems to be working fine.
Has this happened to anyone else during a repair or battery replacement? If I re-open her 3GS What should I be looking for?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There are 2 gold grounding prongs on connector 7(antenna) make sure they are in contact with the bezel and that no 7 is on properly.
Esta resposta foi útil?
Pontuação 3
2 comentários:
I have exactly the same problem. Do you have a picture of what it should look like?
por
take a look at any of the guides on the right under the photo of the iphone.. examine the dock connector and you'll see the 2 grounding prongs and connector 7...
por
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 2,771
