Volvo XC90 2.5T Will Not Crank, Starter, Relay, Fuses All Good?
All of a sudden with no warning stopped and would not crank, no immobilizer activated, just won't crank, had to have towed home, checked starter, jumping pin 87 to 30 cranked starter, so it is not starter, swapped starter relay, checked all fuses with meter, pulled halo to check connections, pulled apart ignition and sprayed electronic cleaner on contacts and connections, nothing has helped. Any suggestions on how to resolve this mystery.
Esta é uma boa pergunta?
8 comentários
Greetings everyone,
I hope that this issue is been solved by now. However, for those of you following this thread, I would suggest to check the battery first. Are all the components getting electricity, can you hear the fuel pump running. Just asking, by any chance did you get new key fobs?
Best of luck to you all!
por claumy
Turned out to be transmitter in key, crazy, took a month in Volvo service after having to tow XC90 to dealer, another $250. after having it towed home for $125., then dealer says need new key, had to order from Sweden, another two weeks, and finally, It starts, but with bill of $550. I said the key was more than the XC90 was worth. lol
por M Sullivan
Dear Friend
I have a similar case with a 2018 XC90. The motor turns Y turns but does not start. Everything started since the airbag module was changed for a new one. but even though the original airbag ecu is returned the engine does not start. any suggestions?
thanks for your help
por Anibal Chaccha
When you mention changing the airbag, that seems to imply an accident? There are many things which you have to check if you have not already. First, does the locking of your vehicle set the alarm system, as in, the blinking light activates, then leave window open, open door, see if alarm goes off. Sounds crazy, but this alarm system will cause no start conditions. So verify alarm is working properly first.
Obviously, check all fuses, a blown fuel pump fuse can cause crank no start condition, as will the fuel pump relay. You can look under the hood and fuse box is easy to access on driver side in square plastic box in plain site. Pull cover and you will see lay out chart, look for related fuses for fuel pump, you can swap the relay with other like relay in box. You will see several are the same relay, so easy way to diagnose with no cost or tools needed.
CONTINUED:
FORCED-SUCCESS-SYSTEM.com
por M Sullivan
CONTINUED:
If you have verified you have fuel to engine, then check spark, not as easy, for you need tools to pull a spark plug coil and insert screw driver into the end of coil obviously leaving it connected, place near engine and have someone crank the engine, you should see a spark at the point of grounding screw driver to block of engine, WARNING, do not touch metal of screw driver, hold plastic handle to position near grounded block to see spark. If no spark, that points to other fuses, so check related fuses again. There are also fuses in the drive side dash panel, as well as under steering wheel to left, as well as in rear driver side compartment panel, check them all, there are dozens of fuses which may be your issue.
CONTINUED:
por M Sullivan
Exibir mais 3 comentários
