Ir para o conteúdo principal
The third generation of the Samsung Galaxy Note phablet series released September 25, 2013. Identifiable by the model number N9005.
248 Perguntas Visualizar todos
Getting hot around the camera and battery draining
Hello.
I have Samsung note 3. It gets hot upoer part of the back and around the camera. It drain the battery really fast. I bought a new battery and it is the same thing. Getting hot and draining the battery fast. Any help? Thank you.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Hi Aden Crater, Sorry to hear your having Trouble with your Note 3.
This is most likely just because theres a few applications running in the background then the phone can handle and your ram (random access memory ) might be a little backed up. first you'll need to clean up all the temporary files located on your phone, this can be done with a program called ccleaner (you can find it on the play store) just intall and run its cleaner to get your phone in order. Learn how by useing the following link:
http://bit.ly/androidccleaner
Next, you'll want to limit the amount of applications running in the background. Check out this neat form below that will walk you through it
http://bit.ly/applimitaionsandroid
If you have anymore questions fill free to email me at dextech87@gmail.com
Best Regards,
Devin A. Stokes
Repair Technition
DexTech Solutions
Esta resposta foi útil?
Pontuação 0
I don’t know.haha…
Pontuação 0
1 comentário:
I have this problem too. haha
por
Adicionar a sua resposta
Aden Crater será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 1,604
