Ir para o conteúdo principal
Repair guides for phones designed by General Electric.
12 Perguntas Visualizar todos
How can I take apart the handset to change the battery or microphone
People have a had time hearing me using the GE 2-9220 NIC handset. How can I take apart the handset to either change the Lithium battery (which it apparently has) or change the microphone? There are no obvious places for screws. There are internal catches at the bottom near the cord.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Here’s the user manual on it but I don’t see a battery replacement:
http://phone.manualsonline.com/manuals/m...
See id this helps:
Volume
You may adjust the ringer, speaker, handset and headset volumes independently with
the VOLUME ^ and VOLUME v buttons. Your telephone comes with predetermined
settings which can be adjusted to individual taste. You will hear an error tone when
the maximum or minimum volume level is reached. During volume adjustment, a
"dashed line" icon shows in the display.
Adjusting the Ringer Volume
Press the VOLUME ^ or v button while in on-hook mode.
NOTE: To turn the ringer off, on, or change the ringing pattern, see
Selecting A Ringer Tone.
Adjusting the Handset Volume
Press the VOLUME ^ or v button while the handset is in conversation mode. You may
choose from four volume settings: LOW, MID1, MID2, and HIGH.
Adjusting the Speakerphone Volume
Press the VOLUME ^ or v button while in speakerphone mode (SPEAKER indicator is
on). You may choose from four volume settings: LOW, MID1, MID2, and HIGH
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Steve Summers será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 10
Duração total: 112
