Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
MacBook wont boot without battery light indicator plugged in?
Hello,
recently i changed thermal paste on my macbook but accidentaly i broke up an strip connecting the battery light indicators with logic board so i unplugged it.
Now the problem is that mac doesn't boot up anymore and only reaction to charger is its reaaaaly low green light, almost unseenable.
Could the lack of this plug be the problem and will replacing it will help me?
Sorry for english, thanks!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hello again,
i have no idea how and when but today i have just teardown everything and plugged all back and now it all works without battery indicator.
My only idea is that the keyboard connector was plugged in not deep enough because it was the only thing i could plug in just a bit deeper (around 0.5 - 1 mm)
Anyway, macbook has its life again so the only thing to do is to wait for new battery indicator.
Thanks!
por
Adicionar um comentário
1 resposta
Solução escolhida
Not sure what you did here somehow you’ve damaged something in the process. The logic board has the charging control logic so it is now having problems. Did you reverse or damage one of the other cables?
I would recommend you follow this IFIXIT guide in taking your system apart again to see if you made an error some how: MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement In addition what thermal paste did you use? Some are conductive so if you applied too much it will leak out and can damage the logic board.
Take a few pictures and post them here maybe we can spot what went wrong Adicionar imagens a uma pergunta já existente
Imagem de MacBook Pro 13" Unibody Mid 2009 Logic Board
Guia
Nível de dificuldade:
Difícil
40 minutes - 2 hours
Imagem de iFixit
Guia
Muito fácil
2 - 5 minutes
Esta resposta foi útil?
Pontuação 2
1 comentário:
FYI: the battery tester can be left disconnected without effecting things (making sure the ribbon doesn't short anything out).
por
Adicionar a sua resposta
Mariusz Wrzesniak será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 168
