Ir para o conteúdo principal
LTE-enabled variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
46 Perguntas Visualizar todos
Home Button Not working (Touch ID works)
Hi, i have an iPad 2017 (5. Gen with LTE) where Touch ID works flawlessly, but not the click itself. The home button does mechanical click, but the ipad does not react to it. I’m using the ipad with assisitive Touch at the momemt.
I got the ipad used already with this issue, so i dont know what could have caused this.
Is there anything i can do to get the home button working again?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
1 resposta
Pergunta mais útil
It could be due to a loose home button cable, you may need to reseat the cable properly.
To do that, you need some tools to remove glass digitizer, I believe iFixit has posted a guide for this.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
meav33 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 389
