Ir para o conteúdo principal
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
432 Perguntas Visualizar todos
How to quit the installer
I have got notification for soft wear update and I have allowed to update. After that my iMac is not opening. Message is showing as follows "macOS could not be installed on your computer. Quit the installer to restart your computer and try again." Now how can I quite the installers?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
what OS X are you running? Which update does the APP store say it is?
por
Adicionar um comentário
1 resposta
Solução escolhida
You should have the possibility to close it from the menu bar but since something went probably bad during install it might be the menubar is not there ? If so you don't have any other alternative left than force shutdown with power button. Hopefully it will boot correctly otherwise you'll have to reinstall the OS.
Esta resposta foi útil?
Pontuação 2
1 comentário:
How can I get OS, it poss lie to download from Apple Store?
por
Adicionar a sua resposta
shamaun1 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 141
