Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone won’t start with new screen but works with the old broke one
My friend came in and had me to change his ip 7 screen which wos totally broken . So I changed the screen and everything went great but when I tried to start it the phone didnot startup it started as long until the Apple logo showed up. So I checked all connectors and everything and still the same issue. Then I thought lucky me I have one more spare screen so I decided to try that one and same issue once again. Well I now tried the old broken screen and suddenly the phone booted up.
The phones home button doesn’t work neither did the proximity sensor but howecome it started up with the old broken screen and not with the 2 new ones?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
I do agree with Jacob's answer, you can try to figure it out if you have free time.
said the two new lcds are defectived is impossible.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Is your friend running the latest version of iOS? I believe a while back Apple released an update so that third-party displays would not work with an iPhone. However, newer iOS updates allow one to use a third-party display. If the phone is not running iOS 11.4, try to update it and see what happens.
Pontuação 1
sounds like a defective screen.
as long as you disconnected the battery before the repair you should be good.
try a new screen as home button connects to lcd and could also be defective/not working:)
Pontuação 0
1 comentário:
Sry both screens worked
por
Adicionar a sua resposta
Kristian será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 75
