Ir para o conteúdo principal
The Samsung NX1000 is a digital smart camera that was released April 2012
20 Perguntas Visualizar todos
Camera says 'card not supported'
Hello,
I have an NX 1000. It has been in storage for some time. Went to use is and the camera gives me the same message when i load an SD memory card, I have tried a couple diffenet cards and also tried formatting a card from an online program. Nothing working. Do I need a Samsung SD card? What cahn you suggest.
Cheers,
Bo
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Bo Weeks you do not need a Samsung card. “This product supports SD (Secure Digital), SDHC (Secure Digital High Capacity), SDXC (Secure Digital eXtended Capacity), microSD, microSDHC, or microSDXC memory cards.” External memory (optional):
SD card (up to 1–2 GB guaranteed),
SDHC card (up to 32 GB guaranteed),
SDXC card (up to 128 GB guaranteed)
When formatting a memory card, always format using the camera. If you format on another camera or a PC, you can lose files on the card or cause a change in the capacity of the card. Formatting the card should be in your Cameras==>User Menu==>Setting Menu==>Setting 1 menu
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Bo Weeks será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Duração total: 1,473
