Ir para o conteúdo principal
12.1" business laptop released in June 2012 by Lenovo. This laptop uses multiple product numbers, which vary based on configuration.
21 Perguntas Visualizar todos
x230 not booting with new CMOS battery installed
When I install the CMOS battery (new) the laptop won't boot...completely dead. This happens even when I re-install the old battery (I have checked that the battery is full)
If I remove the CMOS battery the laptop turns on normally.
I can use it like this but if the main battery runs out I have to change the date in BIOS every time.
Does anyone have any idea why this is happening?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
most likely is the battery is replaced wrongly , check the polarity is correct
Esta resposta foi útil?
Pontuação 0
1 comentário:
No, polarity is correct
por
Adicionar a sua resposta
Banu será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 633
