Ir para o conteúdo principal
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Perguntas Visualizar todos
Is there any way to fix this miscoloring on my screen?
I dropped my phone on cement steps while trying to open a door. The damage is not too bad and I might be able to live with it, but I might as well try to fix it. On the bottom left of my screen there is a patch of green pixels I don't know how to get rid of. I would like the fix to be non intrusive, if possible.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hello,
Sadly I think the problem is that your display has been damaged, causing those pixels to appear, so I can't think of any other solution that changing the whole digitizer. Maybe, if you really want to be sure you could reset the phone to factory settings to see if the software is causing that.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ryan Kauffman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 93
