Ir para o conteúdo principal
Modelos de MacBook Pro com telas Retina de 13" fabricados a partir de 2012.
4681 Perguntas Visualizar todos
Wi-Fi icon won´t show up
I have a MacBook Pro A1502, the wifi icon dosen´t show up, I´ve changed the wifi card and still the same. the Bluetooth is also damage. When I change the card for another one the bluetooth appear, but the Wi-Fi still disable, I can´t start nor create the service throught the terminal, it says that there is no Wi-Fi device. HELP PLEASE!!!
I also try to enable the wifi network service in the terminal but the listallnetworkservices command doesn´t show any wifi interface
Esta é uma boa pergunta?
Pontuação 0
1 comentário
The A1502 covers quite a few different models! Can you pick yours from this listing: A1502 systems
por
Adicionar um comentário
1 resposta
Solução escolhida
I’m suspecting the I/O cable needs to be replaced. Here’s the IFIXIT guide for the 2014 model: MacBook Pro 13" Retina Display Mid 2014 I/O Board Replacement and here’s the needed part: MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable but without knowing your exact system I’m just guessing here.
Imagem de MacBook Pro 13" Retina (Late 2013-Early 2015) I/O Board Data Cable
Produto
$9.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Luis Anniel será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 137
