Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
LCD malfunctioning with a fully working touch screen glass screen
I recently dropped my iPhone 7 on the floor with the back facing the floor. When I lifted it up its shape seemed to be fully intact , it`s LCD was malfunctioning ( It seems as if the upper part of the screen is working but reflecting the lower part of the screen at the same time; there is a crack beneath the glass screen and not on the screen that can be seen when the phone gets lit up) and its glass screen was fully intact. I was able to use all the function on the phone including touch screen, camera and listening to music .
After a few inspections on my phone, I realised it is very slightly bent ( almost impossible to see). The phone`s LCD sometimes works ( the image can be perfectly seen but there are transparent lines going throw it and the crack still stays) and soemtimes doesn`t ( the upper corner of the screen has coloured lines going throw it and the weird reflection can be seen again).
What happened? How much does it cost to rapair? Shpoul I repair the phone?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sounds like you need a screen replacement. Look over the guide and see if it’s something you think you can do yourself, otherwise you can take it to a shop and they will fix it up for you.
iPhone 7 LCD and Digitizer Replacement
Esta resposta foi útil?
Pontuação 1
2 comentários:
how much would it cost for someone professional to replace it
por
Alexander,
My store charges $99 USD to replace the screen on an iPhone 7, but it is going to vary greatly depending on where you are and the stores in your area.
por
Adicionar a sua resposta
Alexander Alexandrov será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 65
