Ir para o conteúdo principal
Encontre soluções para as questões de reparo do seu computador.
21258 Perguntas Visualizar todos
PC boots about 1/4th of time
My pc boots randomly when I start my pc. When I push the 'on' button the fans start spinning, and my motherboard gets power, but my screen doesn't get signal.
I think my pc boots every time with only 4gb ram instead of 8gb.
Specs:
AMD Ryzen 3 1200
Corsair VS450
MSI Geforce GTX 1050 gaming X 2GB DDR5
MSI B350M Gaming Pro
Crucial 2x 4GB stick (in kit)
please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
OK, some things you may want to try.
First update the Bios version you have.
Second try and see if that fixed it.
If Second step failed , Get a new set of ram. Try DDR4 ram with a matching bus speed.
I have noticed that with this motherboard the Ram bus speed is kind of up in the air. I would do some research to get the proper ram bus speed and this could correct the issue. Please update me once you have tested the steps
Esta resposta foi útil?
Pontuação 0
2 comentários:
I updated my BIOS to the newest version and this worked. I had this problem for a long time and updated the bios a couple times, but I guess they changed it in the last version..
Thank you a lot for helping me!
por
No problem. Glad it worked : )
por
Adicionar a sua resposta
Ruben Debbaudt será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 64
