Ir para o conteúdo principal
First Generation Electric Motorized Longboard released by Boosted, June 2014.
8 Perguntas Visualizar todos
Why one of my bushings are bigger then the other
when i turn i feel i can turn easier on the smaller bushing but the othe side with the bigger bushing i feel some restiction going on so i cant turn smoothly
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi tatianbianchidelaroche,
It is possible that the bushing that appears smaller is just more worn away than the other side, for various reasons. It is also possible that if you bought this board from someone else, that they replaced the bushing with a wrong size. I would check into a possible replacement bushing if it is becoming an annoyance or problem for you. It could also just be the way the board is designed.
Best Regards,
Drew
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
tatianabianchidelaroche será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 117
