Ir para o conteúdo principal
2.4GHz, 2.7GHz, or 2.8GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache. Released February 2013.
274 Perguntas Visualizar todos
My charger cable is turning yellow after battery repair
Hi,
I have just changed my battery and everything when amazing but, I have noticed over the past month and a bit that my charger has turned yellow near the connector. Everything is functioning fine. The connector when charging gets very hot within 10 min of charging.
Thanks in advance,
Liam
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
That is a symptom of overheating and the cable should be replaced. You can read more here.
Esta resposta foi útil?
Pontuação 2
1 comentário:
The yellow color is indicative of oxidation, i.e. it is doing a slow burn. Please post a Coconut Battery image with the mag-safe connected.
por
I wonder if there is another problem.  If the problem didn’t start till you replaced the battery, then it could be related to the battery.  Is it possible that the battery is drawing too much current?  That could explain the “slow burn” that is now occurring.  Is the new battery an Apple battery, or is it an “after-market” battery?  If it is after-market, then it could be a defective battery.
Pontuação 1
1 comentário:
Hey, I got my battery replaced as well and this only started happening after for me as well
por
Adicionar a sua resposta
liam será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 2,902
