Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
How do I properly install the external lense back onto my rear camera?
At some point the external lense of my phones rear facing camera popped out of my phone. I ordered a new one but it doesn’t just pop in and stay. What do I need to do to properly reinstall this lense I ordered?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I use b7000 liquid glue on the area where the adhesive usually goes to adhere the rear glass to the screen.
You will need to remove the rear camera temporarily to avoid getting glue on it and dont put too much so that it doesn't cover or smudge the lens area.
If it gets on the glass lens area you use isopropyl alcohol to remove the liquid glue.
Esta resposta foi útil?
Pontuação 1
It should glue in around the edges. Make sure none of the glue overlaps over the edges onto the lens, otherwise your photos will always have a mark on them.
Pontuação 0
1 comentário:
It came with a black frame around the lense though and won’t detach from it. It causes the lense to stick out from the phone and pop out if a case is put back on the phone. Is there anything I can do about that piece?
por
Adicionar a sua resposta
Jillian Strazzere será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 66
