Ir para o conteúdo principal
Guides and repair information for the second-generation of the North American Honda Odyssey, produced between 1999 and 2004.
42 Perguntas Visualizar todos
Why aren't my back windows don't open?
Both windows are not opening and it happened at about the same time.
It's 2004 honda odyssey.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
4 respostas
Pergunta mais útil
Have you checked your fuse yet? the Owners manual says Interior fuse box, passenger side, fuse 7 (L window), 16 (R window). Both are 7.5A ratings. Here is the fix for the actuators as well. Hope this helps. If not give a bit more info like any noise coming from your windows, any clicking grinding etc. Good Luck
UPDATE just got this info I wanted to add to the answer.
"Check the power window relay and check the wiring harness to it. Sounds like you have some intermittent contact. Hav you tired to reset your windows? "Resetting the power window control unit is required after performing the following procedures
• Disconnecting the battery.
• Removing the No. 79 (20A) fuse in the under-hood subfuse box.
• Disconnecting the 18P connector from the power window control unit.
• Removing the window regulator, glass or glass run channel.
• Disconnecting the driver’s door wire harness.
1. Turn the ignition switch off, then back ON (II).
2. Move the driver’s window all the way down by holding the driver’s switch to the AUTO DOWN position; when the
window reaches the bottom, hold the driver’s window switch in the AUTO DOWN position for 2 seconds.
3. Move the driver’s window all the way up without stopping by holding the driver’s switch to the AUTO UP position;
when the window reaches the top, hold the driver’s window switch in the AUTO UP position for 2 seconds.
If the window does not work in AUTO, reset the power window control unit according to the above procedures again. " great information from here. Hope this helps.
Esta resposta foi útil?
Pontuação 4
1 comentário:
I have just a single clicking sound. Every once in awhile the window moves about a half an inch. Then I have to turn the vehicle off then back on...
por
How do I open the 2004 Honda odyssey rear side windowsc
Pontuação 1
I have same van and had same problem. Search other forums for the answer. There is an electrical component in the window motor/switch that you have to heat to melt together. After doing this both rear windows are now working fine. Good luck.. The answer is out there.
Pontuação 0
How do I open my 2004 Honda odyssey rear side windows
Pontuação 0
Adicionar a sua resposta
mirasimrealty será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 92
Duração total: 18,852
