Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930.
425 Perguntas Visualizar todos
Newly replaced screen only shows top of screen, purple lines
Hi I am replacing a screen on my samsung galaxy s7, tear down went smoothly and phone was assembled perfectly. When i powered on the phone the bottom half of the screen is black no picture, but the top if the screen shows the battery indicator, sim info, network signal, ect. Below the indicators on the top of the screen are two purple lines, below those lines nothing but black. The touch sensor is working as when i slide my finger up i can see the clock moving at top of the screen. Is this new LCD damaged? So I should return it for another, or is there something I am missing?? This is an expensive LCD so any help will be greatly appreciated!
Also all connectors are secure, cleaned, and re-fastened multiple times to ensure connection is not the issue.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Its a faulty screen or was broken during installation. I new screen should work.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brennan Dean será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 77
