Ir para o conteúdo principal
The LG K7 is smartphone released by LG in February 2016 and runs on Android 5.1.
reset my pin or google account
hard reset device and add new account
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Solução escolhida
You need remove account from setting first, then just reset your phone.
Esta resposta foi útil?
Pontuação 0
1 comentário:
its locked up now..i can factory reset it but i cannot access any settings without correct info? so if i do factory reset manually it'll be stuck on the google verification account and the person acct it was synced to no longer has access to any of it, dont remember $@$* so now what???
por
manually factory reset, right...BUT how to bypass the google verification or FTR??
Pontuação 0
1 comentário:
aah ic, you have locked FRP
try this method, im successfully with this method
http://www.techoxygen.com/bypass-google-...
Good Luck
por
Hi i need help in bypassing my Lg K9 i am to get on google but its not the same as when i type settings i dont have a prediction so im unable to go on my phone setting isnt there another way ?
Pontuação 0
Adicionar a sua resposta
Nizhoni Luv será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Ao todo: 3,032
