stuck in recovery mode
my Epson WF 2540 printer is stuck in recovery mode and wont work
Esta é uma boa pergunta?
This problem can be occurred when the firmware update process is interrupt such as powering off the product, the installation process is being existed or your cables go out.
What is solution for this?
Oh, it’s depending on your patient. Let’s wait for a few minutes then a pop-up is appearing on the screen of the computer. Click on the link you see below to go to the tool that help you fix this error.
Source: https://resetkey.net/epson-printer-stuck...
Esta resposta foi útil?
If you can reach the printer via the network try to type the ip address into your browser URL . If you can do that you may be able to update the firmware via the web interface and get the printer responding again. My firmware update is under "basic settings" on my epson printer.
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Duração total: 2,179
1 comentário
my epson wf-2510 is in printer mode. i need help
por David Oye
