Ir para o conteúdo principal
O Huawei P8 Lite é um celular Android, lançado em janeiro de 2017. Números de modelo: PRA-TL10, PRA-TL20, PRA-LA1, PRA-LX1, PRA-LX2, TAG-L21, PRA-AL00X, TAG-L32, PRA-LX3, PRA-AL00.
Reboot loop after replacing frame and screen.
Hi! I ordered an iFixit essential electronics toolkit from the EU store and a new frame and screen for my Honor 8 Lite (P8 2017). Once I finally got them, I replaced the broken screen and bent frame, but once reassembling everything and booting the device, I get a black screen with EMUI logo requesting me to reboot the system, doing a factory reset or wiping the cache. I tried factory resetting and wiping the cache, but it still reboots to the very same screen. I've re-seated all connections twice now and I still have the problem. What I am more curious about is why it does this, after all the only part it could know has been replaced is the screen. Please help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Check the power switch first sometime this may causes such issues.If same then firmware upgrade the phone.
Hope this may help you.
Esta resposta foi útil?
Pontuação 0
2 comentários:
By power switch do you mean the power button on the side? It should be fine. Can I firmware upgrade the phone without unlocking the bootloader or anything? I tried going into download mode and using the HiSuite program, but it would get immediately stuck on 5%.
por
you have to download the firmware update.zip and format the memory card to Fat32 and create the dload folder and put the update.zip in there.
Press v-&v+ and press power on until the update process begain.Battery must be 50% charged or connect the charger till update process complete.
por
Adicionar a sua resposta
Henrik será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 1,026
