Ir para o conteúdo principal
issues with car electrical system
Help..I'm not sure what's going on..first off I have a 95 chevy 2500..both the brake light n abs light was on when got it..I plugged in wire for trailor hitch n pressed brakes to check lights n popped fuse replaced #1 brake fuse but it kept popping..so I unplugged the trailer hitch wire for lights..replaced fuse again..it worked this time so I decide to take truck up the road I got about 2 blocks from my house n smoke started coming up around the steering wheel..smelled like wires melting..I haven't a clue..I just changed the fuse that's it..any ideas..
Esta é uma boa pergunta?
Pontuação 1
2 comentários
It melted the wiring harness to the brake light switch..
por
Headlights went out.
por
Adicionar um comentário
1 resposta
Solução escolhida
Definitely a short circuit. Now where it is I'm not sure.
Esta resposta foi útil?
Pontuação 1
1 comentário:
short in the switch itself try replacing it
por
Adicionar a sua resposta
John Faust será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 455
