Ir para o conteúdo principal
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
34 Perguntas Visualizar todos
What screw do I need to remove the top screw?
So I bought a PSP 3000 from Japan and I am trying to get the front panel off.
5/7 screws are standard phillip 000. The other 2 are some other type.
Photo isn't clear but I can see 6 vertices that form a star shape. The screw size is very small. A lot smaller than phillip 000. Even my flathead 1.5 won't fit.
Can anyone please tell me if they know this screw type?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
It is called a Torx screw. They are usually labelled T5 for a size 5 Torx, or TR10 for a size 10 Torx with a indent in the middle for special security screws.
It is found in many consumer products, especially laptops, where they do not want you to remove components or casings. From the looks of it, it is probably between a size T5 and a T3.
I have since sold my Japanese PSP due to financial issues, so I can no longer tell you the exact size. But iFixIt does sell a kit with the available sizes found here: Mako Driver Kit - 64 Precision Bits
Imagem de Mako Driver Kit - 64 Precision Bits
Produto
$39.95
Esta resposta foi útil?
Pontuação 1
I have the ifixit kit with the t4 and t5 bits and both are too big. So am guessing it's a t3.
Pontuação 0
Adicionar a sua resposta
Anthony Siharath será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 21
Últimos 30 dias: 95
Duração total: 2,649
