Phone turns on then off after a few seconds
I have a galaxy core prime and when I go to turn it on the screen shows the Galaxy core prime screen then immediately shuts off.
Esta é uma boa pergunta?
this can be caused by many different problems.
1) battery. The device's battery can be failing to put out the proper current, causing the device to time out.
2) Software. your device could have a software failure, and not understand what to do in order to fully boot.
3) Modular Short. a short circuit in a modular component could cause excess current draw. this would cause issues with the device not being able to boot.
4) motherboard failure. Be it a short circuit, cold circuit, or a fried fried component, the logic board can easily cause this type of issue if it is failing.
Troubleshoot with these 4 components to see which one it is.
Esta resposta foi útil?
Are any of the last three listed fixable? And if so, where do i go to in order to find resources how to fix this myself?
GT S5222 tran on off afeter seckand
samsung s5222 phone turns on off after a sacknd
prende y se apaga igual la batería se agota rápido
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 62
Duração total: 4,077
