Ir para o conteúdo principal
Released September 2016, the Vivo 5R represents the sixth generation of the Vivo series and an update to the Vivo 5.
Stuck in a reboot/optimising app 1 of 1
My Blu Vivo 5R has been stuck in a Restart / 'Starting Android - optimizing app 1 of 1' loop for several hours. The battery cannot be removed and I can't find any workable solutions to reboot or access factory settings.
I installed 2 new apps this morning (MyFitnessPal, Strava) and this has been happening since about an hour after that.
Can anyone help?! If I could just get to the main screen I can uninstall the apps that seem to have caused the problem, but it won't get that far in loading. It won't connect to my PC to access from that side either.
Any advice much appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
At this point now that you can’t even load and get into your home screen, I believe the only thing you could do is factory reset the device and clear all the memory. Then restoring a backup of the data before the apps were installed if you have one.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you - I was kinda hoping that wouldn't be the only solution of course, as my phone numbers are all saved to the phone rather than the sim card. Argh!
por
Adicionar a sua resposta
Genie812 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 12
Ao todo: 5,043
