Ir para o conteúdo principal
O Razer Blade Stealth é um competidor do MacBook da Apple e usa o sistema Windows.
48 Perguntas Visualizar todos
Laptop screen wont turn on but keyboard and razor logo will light up
Is there a way that I can get my laptop screen to work again? The keyboard back lights work and the razor logo on the back of the display works when I turn it on. But I get nothing from the display itself.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I am also able to connect a HDMI cable to it and I can get the laptop to display on an external display.
por
The touch screen works. This confuses me.
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi @birdup
What is the actual model of your laptop?
If you flash your torchlight on the panel, can you see anything on it?
Some issues that could be causing this, e.g. like Faulty LCD module / panel, Faulty LVDS Cable, etc
Esta resposta foi útil?
Pontuação 3
1 comentário:
@birdup "the razor logo on the back of the display works" means you have a working backlight. The digitizer is separate from your LCD and right now it appears as if you either do not get a signal to the LCD or the LCD screen is just not working. Since the external display works I would go with a new screen
por
Adicionar a sua resposta
Harrison Reisinger será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 15
Duração total: 7,099
