Ir para o conteúdo principal
All USB devices are named the same?
Here's my issue:
At one point I renamed a USB to SATA adapter to "USB to SATA" and now since then, all devices are named that if they are in the (only) USB port
example:
In this picture, my new USB drive is connected, (first time used) and named USB to SATA.
same for all other devices.
I'm guessing I named the USB port USB to SATA, but I don't know how to change it back to display the connected device's name
Thanks!
@vehiclefreak409 @avanteguarde
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Looks like a hard drive label.
Right-Click --> Properties, should have a field where you can rename it.
Strange if there isn't one.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Completely forgot about that.
por
Wait now I get it. I was using an older USB 3.0 micro B to SATA and it renamed all devices on it to its own name.
por
Got it figured out?
por
Adicionar a sua resposta
Aiden será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 514
