Ir para o conteúdo principal
HP EliteBook Folio 1040 G1: Power and charging lights blinking
I have a HP EliteBook Folio 1040 G1 (i7-4650U, 8GB DDR3, 256GB SSD) which was working until last evening. Now, if I plug it in, I get a power button blinking on and off, and the charging port blinking between orange (amber) and blue (turquoise). I bought this laptop from a refurbisher, and it has a non-original battery.
I have opened the laptop, unplugged the battery and CMOS battery and plugged it back in, to no luck. I have also pressed the power button for a minute, and still get the issue. I am suspecting that the battery is dead. I have learned that unlike other laptops (Dell, Lenovo), HP routes the charging port power through the battery and then the motherboard, and a dead battery on a HP means a non-usable laptop.
It can also be a motherboard issue on the HP. Fortunately I have another (slightly newer) laptop (Dell Inspiron 2-in-1) which is use for mostly schoolwork and internship (where the HP is used for non-school/work stuff). Maybe the Dell will become my one and only laptop if the HP fails.
I have ordered a new battery (for the HP), but is this problem a battery one or motherboard failure. Or is this issue just that I need to leave the laptop for a few hours. Please help.
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Have you tried taking out the battery and plugging in the charger?
Does it start?
Curious your comment about HP. My Elitebook works fine with no battery and the charger/power supply plugged in.
por
Adicionar um comentário
2 respostas
hey you have to try check on youtube vdo if you can fix it by yourself. otherwise if u have a garruenty then go to the customer care . that will be more beneficial for you.
http://www.mfcs.com.au/
Esta resposta foi útil?
Pontuação 0
Hey, I had the same problem with that laptop. My father dropped the laptop and it started slowly blinking.
In my case I did following:
1. unscrew all the bolts
2. unpin battery
3. unpin cmos
4. hold power
5. connect cmos
6. connect battery
7. run it
On some video lady described that in entire board there is too much power and in my lame understanding pushing power without batteries might discharge whatever there was.
Pontuação 0
Adicionar a sua resposta
Neel Chauhan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 38
Duração total: 5,579
