Ir para o conteúdo principal
Electromechanical calculator which graced many an accountant's desk between the 1920s and 1960s. The underside of the machine has a slot which, if you peer into it with a flashlight, will reveal the stamped designation LA-160-(serial number).
Reccomendations for restoring and cleaning?
I've recently acquired an LA-160 and I will be using your guide to dissassemble it and make sure the innards work correctly. I was wondering, however, if you have any advice on cleaning the insides or anything?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Dug around to double check my work and found this. http://www.vintagecalculators.com/html/m...
Contained within are a operating manual and a more detailed service manual that contain adjustment and lube
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Brandon Mather será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 217
