bent phone will battery charger work?
IPhone 6plus bent will the battery charger pack work phone will not charge
Esta é uma boa pergunta?
Yes. It’s unlikely the bend is only where the charger port assembly is I’d check for any rips in the cables but should be good.
Esta resposta foi útil?
Don't use any bent batteries ever as they can easily damage your phone.
I've had some cases where it damaged the software on the phone causing it to boot into DFU mode and I had to replace the battery and restore the phone at the same time.
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 45
3 comentários
Depends, how bent is it?
por Timothy McEvoy
Battery charger machine
por Battery charging machine
I am at a complete loss to understand what your answer is talking about. Care to elaborate?
por Jerry Wheeler
