Ir para o conteúdo principal
Repair guides and support for all types of batteries.
74 Perguntas Visualizar todos
Is there a discharging device for this gopro karma drone battery?
Is there a way of building a discharging device for a gopro karma battery (gopro karma is a drone) like a bulb that will discharge the battery. The connectors are different and I have not seen anything about it. There are other batteries that has a simple connectors but this one is a bit different.
Update (05/15/2018)
The purpose of having a discharging device is to discharge the battery to a certain voltage so as when you store the battery, the battery life is extended. Of course you discharge it when you have to store the battery for a longer period of time. I have seen some attachments to other lipo batteries to discharge it but I have not seen one for this particular battery. So, is there one out there?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Just curious ,why discharge it?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
You could always use the karma as a discharging device and run the karma for a few minutes before removing the battery and storing it on a shelf for an extended period of time. Otherwise, you could try interfacing to the battery connector and plug in a ~15v fan to discharge the battery.
Good luck!
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
edbaradi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 230
