Ir para o conteúdo principal
Dishwasher by Bosch identifiable by the model number SHU5315UC-06 or SHU5315UC/06.
led display and lights do not work
Have a Bosh logixx dishwasher, It will function by the power button. So will do the job and turn itself off etc........It is meant to have a count down timer on the led display etc but the display and lights are not working.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Have you tried to dissemble it and check pcb? Connectors and fuses especially?
Esta resposta foi útil?
Pontuação 0
1 comentário:
I could not find a manuel guide with a picture...do you know where the fuse are located?
I was thinking it could be a fuse but also need the type of fuse
por
no replaceable fuse on this unit . check connections from the pcb to the lights or replace pcb
Pontuação 0
Adicionar a sua resposta
Mark Marriner será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 1,293
