Ir para o conteúdo principal
Released in June 2017 as a successor to the Surface Pro 4. Also known as Microsoft Surface Pro 12.3". Model number: FJT-00001.
51 Perguntas Visualizar todos
Using Surface Pro 4 (1724) LCD screen to replace Surface Pro 5 (1796)
Hello,
I have a Surface Pro 5 with a cracked screen. I also have a Surface Pro 4 LCD laying around and wanted to know whether I could use the LCD for Surface Pro 4 to replace this screen. The connectors look very similar in pictures, but I can’t open it up to find out as I would prefer to use what I have until I’m ready to spend $230 for a new screen...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Never mind. Found the answer. Thank you
Esta resposta foi útil?
Pontuação 0
2 comentários:
So, what's the answer? I would love to know if they're compatible.
por
No way. The cable hookups are in different locations.
por
Pergunta mais útil
The answer is you cannot use a Surface Pro 4 on a Surface Pro 5. The cables for the LCD and N-Trig chip are different.
Pontuação 1
Adicionar a sua resposta
Quan Hoang será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 8
Duração total: 1,788
