Ir para o conteúdo principal
The Galaxy S7 Edge is the curved-screen variant of Samsung's 2016 flagship phone, the Galaxy S7. Announced February 2016 and released on March 11. Model SM-G935.
G935F FRP bypass , stuck on downgrade
Hello, i have g935f s7 edge with FRP, downgrade with odin not possile, stuck on error sw rev check device 2 binary 1... also realterm not work, bluetooth headset not work... i think is 2018 security patch..
some ideas pls? :/
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
5 respostas
Pergunta mais útil
You can use latest method to bypass FRP lock from your phone very easily. Just check out here: https://www.bypassfrpfiles.com/2018/11/b...
If you need any tool you can check out here as well: shorturl.at/avIP8
Esta resposta foi útil?
Pontuação 1
are you looking for Bypass FRP Samsung Galaxy S7 Edge? If so, then you are in the right
'''Bypass FRP Samsung S7 Edge – All Methods'''
Pontuação 1
just flash any 6.0 firmware only select boot system recovery
Pontuação 0
1 comentário:
Great! And how do I do that?
por
You can bypass frp galaxy S7 and Galaxy S7 edge using most latest 2019 frp bypass method. In this method you don’t need to go through (Add Call | Talkback | PC | FLASH ).
This is very easy method to bypass frp lock using 2019 frp method.
'''Click here to unlock Samsung Galaxy S7 edge & Galaxy S7 FRP.'''
Pontuação 0
you try flash firmware latest version and FRP WITHOUT PC
Pontuação 0
Adicionar a sua resposta
VojTech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 2,822
