Ir para o conteúdo principal
Lançada em setembro de 2015, a JBL Xtreme é uma caixa de som Bluetooth portátil, que também é resistente a respingos de água.
Is it possible to run JBL XTREME without battery?
Hello,
My JBL Xtreme is not charging, not working. Just blinks one led white then blinking red and repeats.
I have removed the battery and connected charger, it did not worked. And same blinking.
I have disconnected the charger and connected DC 8V power source to power socket on board. No lights came out but it sinks current 0.25 A. I have tried to power on but no luck.
So if my JBL XTREME doesnt have a motherboard issue, is it possible to run it remove the battery and connecting device to a constant DC power source.
Esta é uma boa pergunta?
Pontuação 3
2 comentários:
i have the same issues
por
I have bought 2 charger cords in 1 year. These speakers are garbage and I will not be buying another. Almost $100 for a new cord…lol
por
Adicionar um comentário
3 respostas
Yes it is, i just removed my own battery, the unit is working fine
Esta resposta foi útil?
Pontuação 0
4 comentários:
How to power the jbl Bluetooth speaker when u remove bettery. How we can give it direct power without bettery
por
i'm trying to do the samething with a boombox. bypass the baterry and give power from the ac board to the motherboard. but i didnt know how for now
por
How long time your JbL working without the battery? Its safe ??
por
My jbl extreme its still work without battery with power supply from charger (after im removed that battery).. but im worried if use it for long time
Pontuação 0
My extreme 2 speaker has one bar of battery life left. It powers on but won't charge. I have taken the battery out and connected the wall charger and it does not power on. I'm thinking it's a power cord issue. Will be buying a new power cord
Pontuação 0
4 comentários:
It’s not a cord issue,I’m suffering same
por
I have the same issue now, did you find any fix for it?
por
totally same problem here
discovered power supply to the battery is out haven't fixed mine yet since am in Nigeria and things are hard to get but iv'e been experiencing a delay in charging response might be charging unit
por
I have the exact same problem.I own 6 of them so I know its not the power supply. I don't think its a faulty battery either because I have always used it plugged in to a wall outlet
por
Adicionar a sua resposta
the_mesa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 23
Últimos 30 dias: 98
Ao todo: 12,443
