Ir para o conteúdo principal
Informações de reparo para os Apple Earphones que incluem um controle remoto e microfone. Lançados em 2009. Número do modelo: MB770G/B.
Apple earphone are not working.
I have a pair of Apple earphones but only one side of my earphones work. Is it possible to repair them or not?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
It would probably be cheaper to just replace them with an affordable model.
por
Adicionar um comentário
1 resposta
Well start by using a different device (iphone, ipod, or mac): It could very well be the jack, rather than the deadphones.
next, lace the traces with solder: they could be worn down, and a thin layer of solder could make the connection good again.
if these two options dont work, you have a physical break in the headphones, and the amount of labor involved in fixing them, is worth FAR more than just buying a new pair for 40$. this can be found here. https://www.apple.com/ca/shop/product/MN...
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jessica Patel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 6
Ao todo: 241
