Why is my on call speaker option is disabled after IOS 11.3.1 upgrade?
I got my screen replaced by local vendor and then upgraded the phone after couple of days... since then my on call speaker function isn't working.
Esta é uma boa pergunta?
On my experience this is what you can do:
1. Restore to factory setting via iTunes. if still fail then,
2. If you can test another proximity sensor. if still fail then,
3. You will have the next issue.
- Faulty soldering on the Audio IC chip and this can be fixed by the jumper wire - reball method.
A somewhat difficult task if you are not familiar with this type of repair level.
I have fixed 5 phones with this exact same issue, already fixed.
Esta resposta foi útil?
Bro understand the problem first, I have clearly mentioned that my phone was working fine with replaced screen till I updated to IOS 11.3.1....the issue must be on the software, thus I am expecting some software solution
There is NO software solution
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 705
