Ir para o conteúdo principal
Also known as the SNES Mini, SNES 2, or SNES Jr, this is the compact redesign of the Super Nintendo Entertainment System. It was released in North America on October 20th, 1997.
7 Perguntas Visualizar todos
Led light is on, but nothing else works.
Led light burns, but nothing else.
How can I check if a snes is actually broken?
I recently bought a pretty cheep snes, it was missing several kabels. I still had some kabels, and tried hooking it up. Following a guid, because I had not done so before.
But the it wouldn't turn on. It does have a working led-light, so I know it has power.
All the voltages check out as well so I couldn't have killed the snes.
I would like to check if there is something wrong with either the way I tried to set it up, or the kabels, or even the tv.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You should repost this question under the other SNES category, maybe you’ll get some answers there. This model of the SNES doesn’t have an LED light because it is the cheaper budget version.
But my advice would be to first check the connection to the television. Are you using the composite (red-yellow-white) cable connection, or the RF (gray box with screw cable) connection? I have had RF connections go bad with my SNES that make it seem like it is not working.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Sanne Maaike será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 371
