How do I replace the axles?
Esta é uma boa pergunta?
One kind: Remove axle pin (under hubcap) & slide out.
Another : The axle has a flat-indentation that will not allow removal from the braces. You must remove the braces & turn them to align the slots.
Yet another: more modern: A spring-steel clip that 'bites' the axle. Often has a plastic or tin cover. Replacements found on eBay.
Post a picture... get an exact answer. The years of Radio Flyer is more than me !
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 1,862
