Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Building Own iPhone From Scratch
I wanna build my own iPhone from scratch and I wanna know that, I have a Housing without Flex. If I buy the rear cam, do i need to buy the bracket, connector bracket? Your help is appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
4 respostas
Pergunta mais útil
Travel to China, spend at least a few months in Shenzhen, that's all you'll need to do!
Follow Scottys' travels here where he did it How I Made My Own iPhone - in China and do review what Scotty spent building his How Much Does it Cost to Make Your Own iPhone?
Getting the parts here in the states will cost you more than three times what the phone costs as there are just not enough junkers yet and even then you'll end up having to buy some parts a few times as you will likely get some bad parts as well.
Esta resposta foi útil?
Pontuação 3
3 comentários:
Yeah but I kinda order from AliExpress, so the price will be okay. So should I buy those 3 parts or should I just buy the rear cam module and it includes both the bracket and connector bracket?
por
and... and... It's a lot more than that!
por
Luke 14:28 For which of you, intending to build a tower, sitteth not down first, and counteth the cost, whether he have sufficient to finish it?
por
Which baracket are you referring to?
The one that goes over the top of the camera or over the top of the connectors?
Either way they are not included.
The logic board is the most expensive part and hardest to source, especially seeing as it's going to have to include its matching home button.
Pontuação 1
1 comentário:
Okay, thanks for telling. Appreciated that !!
por
I've already done this. Its great learning experience!
Go ahead and assemble your own iPhone!
Pontuação 0
I bought all my parts from eBay. It does cost more than a new. But I am committed now… any help would be appreciated. Using my droken phone to a new chassis . Some screw positions do not line up. Mainly offset screws.
Pontuação 0
Adicionar a sua resposta
Dillon Clark Tan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 9
Ao todo: 1,312
