Ir para o conteúdo principal
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Perguntas Visualizar todos
replaced screen and dispay wont work
I am replacing my front glass and back glass and before I attached either screen, I hooked up the display to see if it worked and the phone will turn on but the display wont work? ive hooked up everything on the motherboard besides the fingerprint sensor. what could I have done please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
First put back the original screen to see if you see anything.
If the original screen is showing you data then your replacement screen Is malfunctioning.
Esta resposta foi útil?
Pontuação 1
3 comentários:
its the same old screen, I just put new glass in and the display has a little tear in it??? that might be it
por
and the layer between the glass and the copper piece was stuck to the old glass and messed up so I just ordered a new copper piece and screen
por
if the display has a tear in it. Look no furhter.
you need to replace it.
por
Adicionar a sua resposta
Braden Farnworth será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 61
