Ir para o conteúdo principal
Won’t hold charge
If my iPod doesn’t hold charge is it the battery or the logic board
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Are you syncing to a Mac or PC?
por
Adicionar um comentário
2 respostas
Battery. If it boots with a 10W adapter, then the battery needs replacing. Replacing your battery requires a solder and is very hard, similar to an iPhone 2G.
iPod Touch 3rd Generation Battery Replacement
Esta resposta foi útil?
Pontuação 0
Most likely it is the battery that needs to be replaced. If the ipod were damaged in some way then there could be a possibility that the logic board is damaged but the only way to tell would be to replace the battery.
Pontuação -1
Adicionar a sua resposta
Eric hyde será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 110
