Ir para o conteúdo principal
Released in 1989 by apple computer, discontinued in 1991
20 Perguntas Visualizar todos
How do I fix a macintosh se that doesnt boot?
I have a macintosh SE that doesn't boot up. When I power it on, it doesn't bong and it displays the sad mac along with the error code. I am unable to find the specific error code, so I'm not sure what is wrong with it. If anybody knows what hardware error the code is respoding to, that would help alot!!!
Thanks!
The code is
03030305
03030323
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hi @wowitsamac , had you tried opening up ?
take caution when working, as CRT can hold some electric charges,
btw FYI
http://www.nightfallcrew.com/27/08/2011/...
por
Adicionar um comentário
1 resposta
Pergunta mais útil
The most common issue on this model is bad capacitors. Open it up and look at the "cans". Examine for leakage and/or swelling. If you find that is the case, I can give you further instructions.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Yeah I figured. I also wanted to just simply reseat the ram and stuff on the motherboard and replace the battery, but unfortunately I dont have a long enough screwdriver to unscrew the screws in the handle.
I wish I could see what the error code means so I can see where to start, but I will definitely chrck the capacitors!
por
It's a T8. The best one I have also has a case spreader on the other end and is a home made job.
por
Adicionar a sua resposta
Albert Einstein será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 349
