Ir para o conteúdo principal
The PSP 300x was released in the U.S. on the 15th of October 2008. Repair of this device requires only common tools.
20 Perguntas Visualizar todos
PSP won't turn on without AC; and it will shut down short after
Can you diagnose for me what this means? Video link below
https://www.youtube.com/watch?v=M9f_ilNv...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @intagaming ,
The first thing to try is to replace the battery.
Failing batteries can give unusual symptoms.
Start with a known good battery and then check if there are any other problems.
Alternatively measure the voltage of the battery and check what it is as opposed to what is should be as stated on the battery itself. (do this out of circuit)
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
An7 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 282
