Ir para o conteúdo principal
Repair guides and disassembly information for Huawei's P-series Android smartphones.
795 Perguntas Visualizar todos
How do I replace a broken screen on the Huawei P Smart?
Hi, I have ordered a replacement digitizer for the P Smart but I can't find any tutorials on how to fit the replacement screen.
As far as I can see there are no screws visible to open it up.
Can anyone help or does anyone have any experience doing a screen replacement for a Huawei P Smart?
Thanks in advance
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
5 respostas
Pergunta mais útil
The Part
https://www.tvc-mall.com/details/oem-lcd...
The procedure
https://www.youtube.com/watch?v=tN9e7xOJ...
Esta resposta foi útil?
Pontuação 2
4 comentários:
just watched the end of the video. DO NOT USE A BONDING AGENT LIKE THAT. use 1mm double sided adhesive and DAB bonding agents on corners and sides. The amount they used can easily cause damage to components
por
The part I have purchased is this.... https://www.parts4repair.com/touch-scree...
I bought this as the phone functions fine but the screen is cracked and I was l led to believe that only this part would need replacing.
Is this possible? thanks
por
i havent done the repair on this device myself specifically, however, it may be possible.
i would need to physically hold the phone to see if the two parts are serperable. (you feel a little give, before it connects to the LCD)
if they are sepreable, then the repair is very similar, but you lift the Digi from the LCD instead of the whole assembly from the bracket.
I can not find any video guides for this unfortunately, so you will have to be at least some one intuitive to do this part.
por
Thanks for your help Scott
por
i will publish soon a video
Pontuação 1
2 comentários:
Thanks, can you link me in here when you have please?
por
I changed the lcd huawei p smart
But its not giving display
Its just vibrating
por
Wish I saw this earlier… but for future reference if it may help anyone; Huawei offers a free screen replacement within the first 3month of purchase.
http://consumer.huawei.com/minisite/nz/v...
Pontuação 1
How much will it cost for my screen
Pontuação 0
How much to repair LCD and Screen repair for P Smart 2019
Pontuação 0
1 comentário:
you will spend about 35$US
por
Adicionar a sua resposta
john wilcox será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 23,387
