Ir para o conteúdo principal
Model: HX9300 Series The Philps Sonicare DiamondClean Series can be identified by its model family number: HX9300. All HX93xx models are the same toothbrush. The third and fourth number determines the contents of the box. The numbers after the slash (/) determine the color of the handle.
15 Perguntas Visualizar todos
HX9360 can't turn on
I measure the battery about 3.8V.(F1 /R6 point).So I think the battery is fine.
But I push the button can't turn on it.But put into the cup can charge the battery.
So how do I to check the board or more action?
thanks
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I have probably a similar issue. Who can find and change a battery here?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
swat1230 your voltage maybe fine but it is not a good indication of your battery being okay. It is possible that your battery simply does not hold enough charge to supply the demand. I'd start with a new battery first, then re-evaluate. Check your switch circuitry etc. with your multimeter.
Esta resposta foi útil?
Pontuação 3
I'm having the same problem. Have you fixed it?
Thanks!
Pontuação 1
2 comentários:
I have also checked the switch circuitry, which is fine. Additionally I have also connected an external power supply with 3.8V. Unfortunately it didn't helped.
por
I have exactly the same issues, battery power is still good. Have so. fixed the problem yet?
por
Adicionar a sua resposta
swat1230 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 20
Duração total: 2,054
