Ir para o conteúdo principal
Model A1418 / Late 2013 / 2.7 & 2.9 GHz Core i5 or 3.1 GHz Core i7 Processor
254 Perguntas Visualizar todos
What size Hard Drive do I replace the existing one with.
Can you tell me what size or type of drive I need to replace what I have. That would be greatly appreciated.
If you could point me to a cheap one on Amazon the is around 256 GB that would be very helpful.
It would go into my 21.5" iMac that is around 2013 or 14.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Here are the specs for your Mac: https://everymac.com/systems/apple/imac/...
Given that you are looking for a "cheap" one on Amazon, I'm going to assume you are not looking to replace a Fusion Drive setup.
Essentially, you want a 2.5" drive with a SATA III 6 Gb/s connection. So you can search wherever you want for the best deal. I've provided a couple of examples below.
Cheap Option: For a regular 250GB HDD: https://www.amazon.com/250GB-Inchs-Drive...
Performance Option: If you want to spend a little more money for a 250GB SSD (recommended): https://www.amazon.com/dp/B0764WCXCV/ref...
Use this iFixit Repair Guide to help with the replacement: iMac Intel 21.5" EMC 2638 Hard Drive Replacement
Esta resposta foi útil?
Pontuação 1
If you are going to be opening up that computer it would be well worth it to replace the existing hard drive with a solid state drive! Just make sure you have all of the pieces to do so: SSD, and adhesive strips. https://smile.amazon.com/Crucial-MX500-2...
Pontuação 0
Adicionar a sua resposta
Luke será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 164
