Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1185 Perguntas Visualizar todos
Black Screen Mac, but normally working with external screen
It happened to me from out of nothing to get a black screen in mac. I went directly in google to inform about this and the solutions with Pram and so on didnt work. I tried using an external lcd and saw that it worked normally just the screen is black. If i turn the brightness high it goes a little blue but i dont see nothing. It even detects the screen at display. I dont know if it is a software problem or maybe the cables connecting to the logic board have some problem. Any suggestions? Should i reinstall os or maybe is it hardware? Actually i am using this mac right now :)
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Shine a light through the Apple logo and see if you can see anything on the screen. Also use a known good test screen if you can to see if it's the screen.
Esta resposta foi útil?
Pontuação 0
6 comentários:
I can see some small light passing through the apple logo on the screen. Just this. Does this mean anything?My hunch is that the cable is not connected correctly to the logic board and maybe i should open it and replug it once more. dont know
por
No like if you boot the computer and it chimes, do you see and Apple logo and a loading bar through the Apple with the light or do you see no picture?
por
No i dont see it
por
Then you want to try a different screen first if possible.
por
what do you mean by another screen?
por
Exibir mais 1 comentário
I think you should try reinstalling the software. If this doesn’t work, be sure that everything is secured inside correctly. If all else fails, it’s probably the hardware. Get Apple to help if this doesn’t work.
Pontuação 0
7 comentários:
@ps3fanatic it is illegal to manufacturers to prevent a person from repairing their own device. There is no such thing as "voiding your warranty". This is federal law.
https://motherboard.vice.com/en_us/artic...
por
Thanks. I was a bit confused, since i’m only used to things with warranty.
por
Like a PlayStation 3.
por
@ps3fanatic Everything and anything can be modified or self repaired and it won't void the warranty. Read the law included in the link I sent you.
por
Oh wow, I never realized this. Thanks again!
por
Exibir mais 2 comentários
Adicionar a sua resposta
Parid será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 409
